640
Exception after downgrading from 2008 vol3 to vol1
I'm working on an ASP.NET app using the NetAdvantage 2008 vol 1 controls. A couple weeks ago, my machine was affected by the Conficker worm, and the It group here stripped my machine. When I reloaded the NetAdvantage controls, I mistakenly installed vol 3 instead of vol 1 and ran the upgrade utility when I had some errors.
I ended up uninstalling and installing vol 1 again and running the upgrade utility, but now I have an intermittent problem where I launch my app, and when I navigate to a page with the Infragistic controls, I get the following error:
An Exception of type 'System.IO.FileLoadException' occurred in webpo.dll but was not handled in user code. Additional information: The given assembly name or codebase was invalid. (Exception from HRESULT: 0x80131047) Break/Continue
I have found that if I break, stop debugging, and Rebuild the Solution, it works fine for a bunch of debugs, then comes back.
I had never received this error before.
Any idea what's causing this and how to solve it? Visual Studio 2005 VB.NET Thanks! Chris
