1600
How to identify which node is selected when multiple nodes have the same text
If every node has its own unique text, this is very easy.
in
Handles UltraWebTree1.NodeSelectionChanged
I can use selectedNode.Text however since there are multiple nodes have the same name this is not going to work.
In Page_Init I added a bunch of nodes and get the index put it into Private variable such as
Private RootNodeIndex as integer
Page_Init()
RootNodeIndex = ANode.Index
and inside UltraWebTree1_NodeSelectionChanged procedure
I used
Dim nodeIndex as integer = selectedNode.Index
Select Case nodeIndex
When I choose ANode the nodeIndex supposed to be the value of RootNodeIndex however
everytime I tested it turns out to be 0.
Looks like the private RootNodeIndex value does not hold as it did before postback.
Do we have any good resolution for this matter?
  • 570
    each ultrawebtree node has 2 additional properties. They are:
    1.) node.Tag
    2.) node.DataKey
    while initializing a tree, you can use a variable to set value with each node's tag property and increment it, so that each node gets unique tag. And inside the void UltraWebTree1_NodeSelectionChanged(object sender, WebTreeNodeEventArgs e) method, you can use:
    int tag =Convert.ToInt32(e.Node.Tag.ToString()); to retrieve unique tag for each node.
    And if you need to search a tree for a specific node using its tag, you can use:
    Infragistics.WebUI.UltraWebNavigator.Node searchNode= UltraWebTree1.Find("type the tag as string"); it will find the node with that tag
  • 7694
    You can use the WebTreeNodeEventArgs e to work with current selected node. Please take a look at the code below:
    protected void tree_NodeSelectionChanged(object sender,
            Infragistics.WebUI.UltraWebNavigator.WebTreeNodeEventArgs e)
            TextBox1.Text = e.Node.Text;
            //You can use also other properties of the node:
            //e.Node.DataKey;
            //e.Node.DataPath;
    Also you can take a look links:
    CSOM : http://help.infragistics.com/NetAdvantage/NET/2008.3/CLR3.5/
    Samples: http://samples.infragistics.com/2008.3/WebFeatureBrowser/Default.aspx
    Hope this helps.
