I want to know how to make webcombo to appear in a webgrid cell so you can select one Item from the list and it appears on that cell. OR maybe make a pop-up Grid that consist of list of Items and select one and it appears on the cell you selected for a pop-up Grid to appear.
Helen,
I am new to Infragistics and am able to bind the webcombo to the field and it displays when clicked in the grid, however, when I click the selection from the webcombo, it does nothing. None of the samples or help documentation (even the link you provided above) explains this functionality. What am I missing to make the combo put the selected value into the webgrid?
Thanks much
You need to use the grid's embeddable editor functionality. You can specify an editor to be used for a column in the grid. There's information in the help about how to get this working.
