140
Webgrid Data Loading Problems using ObjectDataSource
I have a ObjectDataSource bound to the grid, the initial data load selects the data from the database 4 times using the same select statement, I have tried setting the datasource at runtime and design time with the same results in both cases.  I know its not the ObjectDataSource because when I bind it to the standard .NET GridView it only selects the data once.
Secondary problem to this is: I have the webgrid in a warp panel, when sending an asynchronous postback using the warp panel, the webgrid then refreshes the data in the grid 4 times using the same select statement before processing the update/insert/delete operation.  This seems excesive and totaly unwanted and unnecessary.  The side effect from this is that it retrieves my concurrency control column from the database when it should be using the value that is in the grid.
Any one else have these sorts of problems with the grid?
