We're needing to embed a WebTree into a WebListbar group but can't figure out how to do it. I've done it before in the WinForms controls but we're rather new to the web controls and they're very different from the client controls.
Also we can't get the Infragistics help to display in Visual Studio Help. This has been a problem ever since we upgraded to VS 2008.
Any help would be appreciated.
Joffies,
Did you find a solution to your question regarding the putting these controls inside of a MasterPage? I have the exact same setup: a Master Page with an UltraWebListBar and a Tree. But when I select an item from the tree, the pages refrehes and the tree gets reset. Thanks.
Hi
I have put the same two controls in a master page which I will use as my navigation mechanism. I am struggling to maintain/understand viewstate when on the weblistbar and WebtreeView when navigating to other pages that are also based on the same master page. There has to be some way to maintain state for the life duration of the session.
So am i right in stating that I will have to maintain state myself (perhaps httpSessionState?) for the UI scenario for both the WebListBar and WebTreeView or is there something else I can do?
John
HelloPlease take a look code below:<iglbar:UltraWebListbar ID="UltraWebListbar1" runat="server"> <Groups> <iglbar:Group Text="2"> <Template> <ignav:UltraWebTree ID="UltraWebTree3" runat="server" DefaultImage="" HiliteClass="" HoverClass="" Indentation="20"> <Levels> <ignav:Level Index="0" /> </Levels> <Nodes> <ignav:Node Text="Root Node"> <Nodes> <ignav:Node Text="Child Node"> </ignav:Node> </Nodes> </ignav:Node> <ignav:Node Text="Root Node"> </ignav:Node> </Nodes> </ignav:UltraWebTree> </Template> </iglbar:Group> <iglbar:Group Text="1"> <Template> <ignav:UltraWebTree ID="UltraWebTree4" runat="server" DefaultImage="" HiliteClass="" HoverClass="" Indentation="20"> <Levels> <ignav:Level Index="0" /> </Levels> <Nodes> <ignav:Node Text="Root Node"> </ignav:Node> <ignav:Node Text="Root Node"> <Nodes> <ignav:Node Text="Child Node"> </ignav:Node> <ignav:Node Text="Child Node"> </ignav:Node> <ignav:Node Text="Child Node"> </ignav:Node> </Nodes> </ignav:Node> </Nodes> </ignav:UltraWebTree> </Template> </iglbar:Group> </Groups> </iglbar:UltraWebListbar>
Also you can take a look at the links:Helps: http://help.infragistics.com/NetAdvantage/NET/2008.3/CLR3.5/Samples: http://samples.infragistics.com/2008.3/WebFeatureBrowser/Default.aspx
Hope this helps.
