1414
AJAX (Smart) Callback for NodeClick event in WebTree
To All,
I have seen significant discussion regarding DemandLoad and a little on callbacks initiated by a WebTree NodeClick.
I have wired the NodeClick as such:
protected override void OnInit(EventArgs e)
base.OnInit(e);tvUnitNavigator.NodeClicked += new NodeClickedEventHandler(tvUnitNavigator_NodeClicked);
and created a NodeClicked handler (sort of dumb, just to test):
protected void tvUnitNavigator_NodeClicked(object sender, WebTreeNodeEventArgs e)
Node blah = e.Node;
I was hoping to save the clicked Node's DataKey to a Session variable for use in a different form.  So, the only server side processing will be to save the node to a Session variable - that is, I really don't want to change the tree and/or rebuild the tree.
Is there a simple solution???
