I'm using Infragistics v. 6.3, and am experiencing an issue with the UltraWebGrid control, in which the vertical scrollbars suddenly shift to the right whenever I try to edit a cell, the contents of which contain a WebDateChooser control. Additionally, I find that when I select the date from the WebDateChooser's calendar panel, the cell does not update. It does update if I go back in again after the first attempt, and then reselect the date. Any ideas???
Craig
Never mind, I figured it out. I set the width in the <framestyle> tag, and everything's good to go.
