When i right click on a node for the first time, the context menu takes some time to load it. But again when i right click on the same node, the context menu will be displayed immediately. Before displaying the context menu i will be checking which node has been clicked and according to that the menu items will be displayed. Some images will be displayed in the menu. Can you tell me what the problem could be? If there is a solution for it can you give it.. Please it's urgent.
Raja.
Hello,When you load for first time context menu in particular images browser display slowly but when they is displayed once they cashed in browser memory and display quickly. Even if you do not use images yourself, the menu is using images through CSS, so the slowdown is expected.Thanks.
