392
Flipping Rows<->Columns?
 I have a list of data objects containing survey responses for various sites {siteName, response1, response2, response3...}.  It is very easy to make a DataGrid with each site as a row and the survey responses as columns (one column per survey question).
 However, I need to present the data the other way.  The indeterminate number of sites need to be columns with each question presented as a row.
 Is there a way to automatically rotate a DataGrid to do this or am I stuck doing it the hard way of mapping my list of data object to another list containing rotated data?
Clark
  • 24671
     Hi Clark,
    Thanks for your feedback - it is currently not possible to do this in an easy way with the UltraWebGrid. What you can do is have a dynamic grid for example, register your own handler for the InitializeLayout / InitializeDataSource UltraWebGrid events, and on a postback (button click or something like this)  manipulate the current grid's layout by adding new columns, removing columns, defining bands (in case it's a hierarchical grid), and so on.
    You can find examples how InitializeLayout is used in the Infragistics Samples Browser ( http://samples.infragistics.com/2008.3/WebFeatureBrowser/Default.aspx) :
    WebGrid -> Defining Layouts
    I hope this helps,
    Angel
