1070
Add, Update, Delete Hierarchical Grid Rows
I have setup a hierarchical grid by manually databinding the grid to a hierarchical LLBLGen Pro EntityCollection. I have created the UpdateRow event to handle Add and Update functionality. Everything was working fine until I added a third band to the grid and the code to Add, Update the third band. Now for some reason only the third band won't work because of a null reference exception which I can't figure out. Can somone look at the attached code in the zip and try to explain why the JobCrewTime band won't work?
JobOrders.aspx.zip
