65
Javasript alert and Infragistics asynchronous refresh panel
 I apologize if I'm not posting this question in the right forum, but here's my problem.
 For this particular asp.net page that I am working on, I have three questions, and for each question the user can answer yes or no via radio buttons.  Initially, the first question is enabled, and the other questions/radio buttons are disabled.  Each question/radio button list is inside it's own Infragistics asynchronous refresh panel.  I did this because question 2 is enabled depending upon the answer to question 1, and question 3 is enabled depending upon the answer to question 2.  I did not want the entire page to be refreshed whenever a question was answered.
 If the user selects the "yes" radio button for question three, a javascript alert should be displayed to the user.  Problem is, that alert does not display.  I think the cause of this problem is the placement of the radio buttons in the asynchronous refresh panel (as an experiment, I removed all of the refresh panels, and the alert displayed when the "yes" radio button was selected for question 3).
Is there a way to make the javascript alert appear without removing the radio buttons from the asynchronous refresh panel?
Here's my code snippet, with the javascript portion in bold:
Protected Sub rbtnlstHalfMeals_SelectedIndexChanged(ByVal sender As Object, ByVal e As System.EventArgs) Handles rbtnlstHalfMeals.SelectedIndexChanged
rbtnlstHalfMeals.BorderStyle = BorderStyle.None
If rbtnlstHalfMeals.SelectedIndex = 0 Then
Response.Write("<script language='javascript'>alert('This student is ineligible because more than 50% of meals are covered by a meal ticket.');</script>")
Session("FL_PLUS_50_MEALS_CVRD") = "Y"
DisableCriteria()
Else
Session("FL_PLUS_50_MEALS_CVRD") = "N"
EnableCriteria()
End If
End Sub
Thank you!
