I have deployed an ASP.NET 2.0 application that is using neadvantage 7.1 for ASP.NET. Sometimes randomly, when a page that contains webdatechooser control is loaded, the following error occurs:
Normal 0 false false false EN-US X-NONE AR-SA MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:Arial; mso-bidi-theme-font:minor-bidi;}
Object reference not set to an instance of an object. Stack Trace: at Infragistics.WebUI.Shared.WebAgent.GetPageControl(Control control) at Infragistics.WebUI.Shared.WebAgent.get_EnableAppStylingResolved() at Infragistics.WebUI.WebSchedule.WebDateChooser.get_IsAppStyling() at Infragistics.WebUI.WebSchedule.WebDateChooser.OnPreRender(EventArgs e) at System.Web.UI.Control.PreRenderRecursiveInternal() at System.Web.UI.Control.PreRenderRecursiveInternal() at System.Web.UI.Control.PreRenderRecursiveInternal() at System.Web.UI.Control.PreRenderRecursiveInternal() at System.Web.UI.Control.PreRenderRecursiveInternal() at System.Web.UI.Control.PreRenderRecursiveInternal() at System.Web.UI.Control.PreRenderRecursiveInternal() at System.Web.UI.Control.PreRenderRecursiveInternal() at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
The user can go further unless the IIS server is restarted. As you can see, all the method call that are involved in the error are from Infragistics and .net framework. Any clue on how to solve the problem?
Note: Sometimes the error appears for other infragistics control such as ultrawebgrid etc.
I'm experiencing the same issue and just submitted a ticket. Wow I hope they fix this soon I've had it happen in two different applications now.
Have you resolve this problem ?
I have the same probleme with WebDateChooser et WebTextEdit (Infragistics 2009 Volume 2)
I submit a support request but I did not get response yet.
FYI ... see the thread addressing this in 2009.2. I was having this issue in 2009.1 and it continues in 2009.2.
http://news.infragistics.com/forums/p/34249/186617.aspx#186617
Rob,
robhudson2 said:How long does it take for a Infragistics to reply to a support request?
It's not yet certain whether the behavior you've described is caused by the development issue I mentioned before.
I'm having your case assigned now. To be fair, this will take us time to verify what's happening in your situation. Thank you for your patience.
Hi Rob,
I haven't seen this issue on our production server since I added the WebDateChooser dll to the GAC. Mind you it was already in the GAC, but since I was getting this error and on occasion one that says:
System.IO.FileNotFoundException: Could not load file or assembly 'Infragistics2.WebUI.WebDateChooser.v8.3' or one of its dependencies. The system cannot find the file specified.File name: 'Infragistics2.WebUI.WebDateChooser.v8.3' at System.Reflection.Assembly._nLoad(AssemblyName fileName, Str
I decided to add a fresh copy to the GAC in case it got corrupted somehow.
I used the DLL from the "C:\Program Files\Infragistics\NetAdvantage for .NET 2008 Vol. 3 CLR 2.0\ASP.NET\Bin" and not from APTCA or Signed folders.
Running .net 2.0 on win2000 advanced server.
Hope this helps
