Hi mates,
I have a hierarchical ultrawebgrid (4 levels of hierarchic) and i would like to when i open de window of the grid, i could see the grid expanded on the level i want. For expand only the second level there aren't any problems because i only have to put one oRow.setExpanded(true), but when i want to expand the third or the fourth level, that means i have to first expand the second level, after the third,..in this order. I tried to put next setExpandeds in the client-event AfterRowExpanded(gridName,rowId) but that give me an error because can't find the row (row = null) that i want to make the second setExpanded.
Can anybody help me?
Marc
Hi, I had the same issue where to place the code to auto expand the 2 levels I had. I placed the code in the UltraWebGrid pre-render event and it worked fine. I also think that you have to use : oRow.Expand(True) property
and not the Expanded property. But I cannot test it out now for you so fast. So let me know if it works.
Good-luck
- Arjan -
