Hi ,
I used infragistics ultrawebmenu in my website.On hovering mouse on menu submenu will not appear .It works fine on IE and Firefox.But it is not working on Google chrome.Any suggestions
Not in my menu.
Maybe an Infragistics employee can tell us what that propertie disables.
Olivier, you rock! My menu now works in Chrome!!
Did you find that making that change adversely affected your menus in any way?
Thanks again!
I had the same problem with the stupid menu. Pff we thought let's buy the controls so we don't have to worry about multibrowser support.
Enough bashing, when I was looking for the problem I found that when you hovered the text in the menu the submenu's disappeared (at first I thought they never showed, because I always point my mouse pointer to the text). When I did this:
FocusOnHover = false
on the webmenu. the most important functionality of the control started working. The submenu's opened!
Hope it helps
btw I'm using 9.1 from infragistics.
Angel, I'm using IG 8.3.20083.1009 and Chrome v1.0.154.48 and opening sub menus does not work.
Do you have any recommendations for me?
Thanks for the feedback . This issue has already been reported and fixed, the fix itself should be available in the latest hotfix for all versions (8.3, 8.2, 8.1, 7.3, and 7.2). Which version do you currently use?
Best,
Angel
