332
JavaScript User Message To Server
In our grid (Version 8.2, .NET 3.5) I want to add a window prompt, asking the user his name, in the BeforeRowDeleted-Handler. How can we get the user-input from the client-side to the server-side? On the server-side we want to add the name to a logfile. The grid is AJAX-enabled.
function UltraWebGrid1_BeforeRowDeleted(gridName, rowId)
   var inputUser = window.prompt("Enter your name:", "");
   //TODO: Make inputUser available at server-side
Thanks in advance for your help.
  • 14049
    You can try to use custom XmlHttp request mechanism that the grid provides:
    http://help.infragistics.com/Help/NetAdvantage/NET/2008.3/CLR3.5/html/WebGrid_Object_CSOM.html
    look for description of the invokeXmlHttpRequest method.
    On the server you can get to the data that you pass in inside of the
    XmlHTTPRequest event handler.
