332
Refreshing after Insert, Update
We're working with a SQLDataSource object and Infragistics Version 20082. After processing an insert or an update to a grid, the rows might not appear in the correct order. Is there a way to refresh the datas of the grid and display them in the correct way? As we work with AJAX-enabled grid, we don't want to do a full-postback.
Example: Our grid contains a column "name" and is sorted according to this. The column holds the names Lorenz, Meier. So, now we change "Meier" to "Huber". Everything works fine, but Huber appears still after "Lorenz".
 Thanks in advance for your help!
