When using the QuickPages option in UltraWebGrid, is it possible to get the elipses buttons that indicate there are more pages to show? This seems to work in WebDataGrid but not UltraWebGrid.
Nick
To be quite honest, I've just started using the Infragistics suite and dove right in with the UltraWebGrid. I wanted to keep all grids on my site consistent, so I haven't tinkered much with the WebDataGrid. It seems like the WebDataGrid might be a bit more lightweight and simpler to use...
Hello Nick,
Thank you for your suggestion. I will add this item to UltraWebGrid's road map. Since you mention that you've checked this feature in WebDataGrid, and that is how you want it to behave, just curious to know if WebDataGrid fullfills your other grid needs and do you plan on using it in your current/future projects.
Taz.
