175
Conditional hide/remove UltraTreeview nodes
Hello everyone,
Has anyone tried the following?
I am using UltraTreeview control in order to retrieve the data from a web.sitemap file.
I have added to the web.sitemap a custom attribute (let's call it CustAtt). Now, when I load the data from the sitemap in the ultratreeview control, I want to display only the nodes that fulfill a certain condition on the CustAtt values. (for instance, CustAtt = "Required".The rest of the nodes (either nodes or leaves) shall be hidden/removed from the treeview.
 I have checked it and double checked it, but i didn't find any solution to this problem.
 Can you help me?
Thank you,
C.
  • 175
    Verified Answer
     Hello everyone,
    I have solved yesterday's problem. Here is the solution:
            protected void UltraWebTree1_NodeBound(object sender, WebTreeNodeEventArgs e)
                SiteMapNode siteNode = e.Node.DataItem as SiteMapNode;
                if (siteNode["CustAtt"] == "Required")
                    e.Node.Hidden = false;
