295
Stationary Footer Row w/ Totals Offset From Columns
Hi.
 I've changed just about every setting and the result seems to be the same every time.  What's happening is that the footer columns are getting offset from the columns in the grid by a few pixels for each column.  The result is that when you get to the 7th or 8th column where the totals reside, the totals don't line up with the rest of the numbers in the column.
I would appreciate any suggestions.
