392
Unchecking all nodes with Javascript
I would like to make the UltraWebTree perform like a radio control in Javascript with a NodeChecked ClientSideEvent. Since there does not appear to be a built in way to do this I figure that Ill have to:
1. Remember what node was just checked.
2. Unselect all of the nodes.
3. Reselect the node that was just checked.
Doing 1 & 3 are easy but I cant figure out how to do 2.  This doesnt work.  It gives a "too much recursion" error (even though the tree is tiny).
function TreeNodeChecked(treeName, id, bChecked)
  if (!bChecked)
    return;
  var node = igtree_getNodeById(id);
  var tree = igtree_getTreeById(treeName);
  // Clear all the nodes.  This doesnt work!
  var nodes = tree.getNodes();
  for (var x = 0; x < nodes.length; x++)
    nodes[x].setChecked(false);
  // Recheck the current node
  //node.setChecked(true);
  tree.setSelectedNode( node );
Any suggestions?
Thanks.
  • 392
    Verified Answer
     Im answering my own question here.  I tried the other ways to make an UltraWebTree act like it has radio buttons.  None of them worked.  This does!
    In aspx:
    <ignav:UltraWebTree
              ID="uwtSiteTree"
              runat="server"
              CheckBoxes="True" HiliteClass="" HoverClass="" Indentation="20" Width="436px">
              <ClientSideEvents NodeChecked="TreeNodeChecked"></ClientSideEvents>
    </ignav:UltraWebTree>
    In BLOCKED SCRIPT
      if (!bChecked)
        return;
      recursive_UncheckAllExcept( nodes, id );
    function recursive_UncheckAllExcept( nodes, exceptId )
      for (var i=0; i<nodes.length; i++)
            var node = nodes[i];
            if( node.Id != exceptId )
              node.setChecked(false);
            recursive_UncheckAllExcept(node.getChildNodes(), exceptId);
    Now we just need to get it so that we can ask the control for its value and it returns the id of the selected node.  Any ideas?
