435
WebCombo Postback Error
Good day.
 i have a webCombo placed on an ASP.NET page.  when the page is first rendered, it is bound fine.  i can select the items as desired.  however, upon a postback, i receive the following error:
 Index was outside the bounds of the array.
[IndexOutofRangeException:  Idex was outside the bounds of the array.]
Infragistics.WebUI.WebCombo.WebCombo.LoadPostData(string postDataKey, NameValueCollection values) + 1243
system.Web.UI.Page.ProcessPostData(NameValueCollection postData, Boolean fBeforeLoad) + 549
system.web.ui.page.processReqeustMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) + 2198
Version Info:  MS .NET, Version 2.0.50727.1433; ASP.NET Version:2.0.50727.1433
any help would be appreciated.
thanks.
