260
DataBinding questions
Forgive me for sounding completely amateurish, but I'm using NetAdvantage 2007 V1 and I'm trying to DataBind to the WebTree and am having a bit of difficulty.  What we are trying to display is a folder hierarchy that is stored in a SQL Database.  All the folder information will be in one table and a folder will be related to its parent via a parent_folder_id.  The dataset will look similar to this
 folder_id   folder_name   parent_folder_id
1               Root             NULL
2               Child            1
3               Child2          1
4               Child3          3
The level depth will be determined after the Dataset is filled.  The only DataRelation I created was from the table to itself via the folder_id and parent_folder_id columns.  I was able to create a tree that had the data nested correctly, the only problem was that the nested nodes also showed up as root nodes with nothing underneath.
How can I accomplish this?
Neal
  • 50
    The above example only works for doing relational tables.... and probably like you was not much help. Below is how I used a single hierarchical structured table to build the Tree control.
    Step1: Declare a publicly accessable DataTable to be used by the funcitons.
    DataSet NavListDS = new DataSet();
    Step2: Add the calls to bind the treview on the first pageview. Note the ID of your UltraWebTree goes here.
        protected void page_load(object sender, EventArgs e)
            if (!Page.IsPostBack)
                // first load DataSet
                LoadDataSet();
                // Build using 0 as the Root ID(Root=0 in DB)
                BuildMenu(UltraWebTree1.Nodes, 0);
    Step3: Add the Functions
        #region UltraWebTree Builder
        protected void LoadDataSet()
            //Custom Query (I actually use the ObjectDataSource and Fill a datatable, but wanted to show ease of use here...)
           //pull your connection string from Web.Config
           String conn = WebConfigurationManager.ConnectionStrings["ConnectionString"].ConnectionString;
            //Select your NodesID, Text(name), and parent node from the table(mine is called NavList)
           String strSQL = "SELECT NodeId, Name, ParentNode FROM [NavList]";
            SqlDataAdapter myAdapter = new SqlDataAdapter(strSQL, conn);
            //Fill that DataSet we created up top in Step1
            myAdapter.Fill(NavListDS, "NavList");
        private void BuildMenu(Infragistics.WebUI.UltraWebNavigator.Nodes nodes, Int32 IntParent)
            Int32 ThisID;
            String ThisName;
           // Pull the NavList Table from the Dataset and filter it down to get just the nodes we are looking for.
           // NOTE  ParentNode is the name of your parent node column in your database
           DataRow[ children = NavListDS.Tables["NavList"].Select("ParentNode='" + IntParent + "'");
           //no child nodes, exit function
            if (children.Length == 0) return;
            foreach (DataRow child in children)
                // step 1, get the Node's ID
                ThisID = Convert.ToInt32(child.ItemArray[0]);
                // step 2 get the Nodes Text
               ThisName = Convert.ToString(child.ItemArray[1]);
                // step 3
                Infragistics.WebUI.UltraWebNavigator.Node NewNode = new Infragistics.WebUI.UltraWebNavigator.Node();
                NewNode.Text = ThisName;
                NewNode.DataKey = ThisID;
                // step 4
                nodes.Add(NewNode);
                // step 5
                BuildMenu(NewNode.Nodes, ThisID);
        #endregion
     Good Luck !
  • 2636
    See Infragistics Example Below:
    You can also get to this by going to http://samples.infragistics.com
            Private Sub Page_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles MyBase.Load
                WebPanel2.Visible = WebSamplesVB.Config.ShowDescription
                ' Put user code to initialize the page here
                If Not Me.IsPostBack Then
                    ' Get Database connection path for nwind.mdb
                    oleDbConnection1.ConnectionString = WebSamplesVB.Config.NorthwindMDBConnString
                    customersAdapter.Fill(dataSet11, "Customers")
                    ordersAdapter.Fill(dataSet11, "Orders")
                    orderDetailsAdapter.Fill(dataSet11, "Order Details")
                    Try
                        dataSet11.Relations.Add("CustOrders", dataSet11.Tables("Customers").Columns("CustomerID"), dataSet11.Tables("Orders").Columns("CustomerID"))
                    Catch x As System.Exception
                        Dim s As String = x.Message
                        Label1.Text = x.Message
                    End Try
                    Try
                        dataSet11.Relations.Add("OrderDetails", dataSet11.Tables("Orders").Columns("OrderID"), dataSet11.Tables("Order Details").Columns("OrderID"))
                    End Try
                    Me.UltraWebTree1.DataSource = dataSet11
                    Me.UltraWebTree1.Levels(0).LevelKeyField = "CompanyName,CustomerID"
                    Me.UltraWebTree1.Levels(2).LevelKeyField = "OrderID,ProductID"
                    Me.UltraWebTree1.Levels(0).RelationName = "CustOrders"
                    Me.UltraWebTree1.Levels(0).ColumnName = "CompanyName"
                    Me.UltraWebTree1.Levels(1).RelationName = "OrderDetails"
                    Me.UltraWebTree1.Levels(1).ColumnName = "OrderId"
                    Me.UltraWebTree1.Levels(2).ColumnName = "ProductId"
                    Me.UltraWebTree1.DataMember = "Customers"
                    Me.UltraWebTree1.DataBind()
                End If
            End Sub 'Page_Load
