380
UltraWebTree has onFocus border
I've noticed that the UltraWebTree has a dotted line around it when I set focus to the control.  I've only ever seen this in IE for embedded objects like Flash movies.  Does anyone know why I would see this for the Tree component in Firefox or other browsers?
  • 25
     Hey jakeharlan_ibs,
    You can also use this CSS property to get rid of the focus rectangle in FireFox, IE, and Safari/Chrome
    <style type="text/css">
    *:focus {outline: none;}
    </style>
    I hope that helps!
    -Tim
  • 28464
    Thanks for writing. Indeed, I was able to reproduce that - it only occurs in FireFox, right? So the problem is, FireFox in general places this frame for all elements that support focus/tabbing/accesskey/keyboard navigation. You can reproduce that even for a simple <div> like that:
     <div id="div2" style="width:200px;height:200px" tabindex="-1">
            fsdfdsfsdds
            <br />
            fdsfdsfs
            <br />
        </div>
    The problem with the treeview is that it always sets tabindex on its main div, hence the focus rectangle. I could not find a property that could switch it off. I however, played a bit with the idea to call blur immediately after focus, and I must say with some pretty good results - this removed the frame for me. Here is my code:
     <script language="javascript">
                function initTree(id)
                    var tree = igtree_getTreeById(id);
                    tree.Element.onfocus = function()
                        this.blur();
                </script>
                <ignav:UltraWebTree runat="server" ID="TreeView1">
                    <Nodes>
                        <ignav:Node Text="Mode 1">
                        </ignav:Node>
                        </ignav:Node>
                            <Nodes>
                                <ignav:Node Text="Node 1.1">
                                </ignav:Node>
                            </Nodes>
                        </ignav:Node>
                    </Nodes>
                    <ClientSideEvents InitializeTree="initTree"/>
                </ignav:UltraWebTree>
    The idea is to get the root Html element of the tree on init and attach a handler for focus that always calls blur. I've tested a bit and this does not seem to have any side effects on my simple setup (but I cannot guarantee that for more complex ones).
    Hope this helps.
