468
Double Click on grid gives wrong results
using v5.2 version. wrong data being retrieved -- when I double click on the grid using active row to get the current row. and noticed that this happens when I sort my column. without sorting the column data retrieved from double click seems to be fine. here is the code Iam using..
Dim intRow As Integer = mygrid.DisplayLayout.ActiveRow.Index
Dim intBand As Integer = mygrid.DisplayLayout.ActiveRow.Band.Index
Dim oRow As Infragistics.WebUI.UltraWebGrid.UltraGridRow = mygrid.DisplayLayout.ActiveRow
Dim intParentRow As Integer
If oRow.HasParent Then
intParentRow = oRow.ParentRow.Index
Else
intParentRow = intRow
End If
Dim strClm As String = mygrid.DisplayLayout.Rows(intParentRow).Cells(1).ToString()
 ex..if I double click on a row that has strClm value 1586 on the grid, my double click returns me 944 as my strClm value.
any insight would be helpful. thanks.
