230
CSS not working
Hi all,
 May i know , why the css setting are not working with ultrawebgrid. In design view i could able to see the colours. While running all become white.
How to make use of CSS in ultrawebgrid?
Thanks !
  • 28464
    Are you using CellStyle and the CssClass property to set the style?
    I think this could be the correct and expected behaviour - the appearance set through styles has higher priority than Css.So I am not sure this classifies as a bug. You are still correct though that it works for some Css styles and not for others
    The point is that some default Css styles are applied to the cell (<td> html element) and some of them involve font-size, font-name, etc. This is the default (or chosen) skin of the grid - this is what makes the grid look good by default. However, if you do need to override that, it is still possible using the reserved Css rule !important - this explicitly overrides any defaults you have for the grid.
    Here is a sample:
     .redCell
            color: red;
            font-size: 20px !important;
        </style>
        <igtbl:UltraWebGrid ID="UltraWebGrid1" runat="server"
            DataSourceID="AccessDataSource1" Height="200px" Width="325px">
            <Bands>
                <igtbl:UltraGridBand>
                    <Columns>
                        <igtbl:UltraGridColumn BaseColumnName="FirstName" IsBound="True"
                            Key="FirstName">
                            <Header Caption="FirstName">
                            </Header>
                        </igtbl:UltraGridColumn>
                        <igtbl:UltraGridColumn BaseColumnName="LastName" IsBound="True" Key="LastName">
                            <Header Caption="LastName">
                                <RowLayoutColumnInfo OriginX="1" />
                            </Header>
                            <Footer>
                            </Footer>
                            <CellStyle CssClass="redCell" />
                        <igtbl:UltraGridColumn BaseColumnName="EmployeeID" DataType="System.Int32"
                            IsBound="True" Key="EmployeeID">
                            <Header Caption="EmployeeID">
                                <RowLayoutColumnInfo OriginX="2" />
                            </Header>
                            <Footer>
                            </Footer>
                    </Columns>
                    <AddNewRow View="NotSet" Visible="NotSet">
                    </AddNewRow>
                </igtbl:UltraGridBand>
            </Bands>
            <DisplayLayout BorderCollapseDefault="Separate" Name="UltraWebGrid1"
                RowHeightDefault="20px" Version="4.00">
                <FrameStyle BorderStyle="Solid" BorderWidth="1px" Font-Names="Verdana"
                    Font-Size="8pt" Height="200px" Width="325px">
                </FrameStyle>
                <Pager>
                    <PagerStyle BackColor="LightGray" BorderStyle="Solid" BorderWidth="1px">
                    <BorderDetails ColorLeft="White" ColorTop="White" />
                    </PagerStyle>
                </Pager>
                <EditCellStyleDefault BorderStyle="None" BorderWidth="0px">
                </EditCellStyleDefault>
                <HeaderStyleDefault BackColor="LightGray" BorderStyle="Solid">
                </HeaderStyleDefault>
                <RowStyleDefault BackColor="White" BorderColor="Gray" BorderStyle="Solid"
                    BorderWidth="1px" Font-Names="Verdana" Font-Size="8pt">
                    <Padding Left="3px" />
                </RowStyleDefault>
                <AddNewBox>
                    <BoxStyle BackColor="LightGray" BorderStyle="Solid" BorderWidth="1px">
                    </BoxStyle>
                </AddNewBox>
                <ActivationObject BorderColor="" BorderWidth="">
                </ActivationObject>
            </DisplayLayout>
        </igtbl:UltraWebGrid>
        <asp:AccessDataSource ID="AccessDataSource1" runat="server"
            DataFile="~/App_Data/Nwind.mdb"
            SelectCommand="SELECT [FirstName], [LastName], [EmployeeID] FROM [Employees]">
        </asp:AccessDataSource>
    In this case, the font-size will be applied always for the cell in question even though there is a different default Css.
    HTH,
