The instructions say
But There's no ScriptManager component in the Toolbox
So the DataGrid Hierarchical now gets ths error. Is the missingScriptManager component the problem?
Line 81: </DisplayLayout> Line 82: </igtbl:UltraWebGrid> Line 83: <cc1:WebHierarchicalDataSource ID="WebHierarchicalDataSource1" runat="server" DataSourceID="SqlDataSource2"> Line 84: <DataRelations> Line 85: <cc1:DataRelation ChildColumns="SCMatrixID" ChildDataViewID="SqlDataSource2_DefaultView"
Version Information: Microsoft .NET Framework Version:2.0.50727.42; ASP.NET Version:2.0.50727.42
DataGridHier.aspx Code Listing
<%@ Register Assembly="Infragistics2.WebUI.UltraWebGrid.v8.2, Version=8.2.20082.1000, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb"
<%@ Register Assembly="Infragistics2.Web.v8.2, Version=8.2.20082.1000, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb"
Namespace="Infragistics.Web.UI.DataSourceControls" TagPrefix="cc1" %>
<html xmlns="http://www.w3.org/1999/xhtml">
<head runat="server">
</head>
<body>
<form id="form1" runat="server">
<igtbl:UltraWebGrid ID="UltraWebGrid1" runat="server" Height="200px" Width="325px" DataSourceID="WebHierarchicalDataSource1">
<Bands>
<igtbl:UltraGridBand>
<AddNewRow View="NotSet" Visible="NotSet">
</AddNewRow>
</igtbl:UltraGridBand>
</Bands>
<DisplayLayout AllowColSizingDefault="Free" AllowColumnMovingDefault="OnServer" AllowDeleteDefault="Yes"
AllowSortingDefault="OnClient" AllowUpdateDefault="Yes" BorderCollapseDefault="Separate"
HeaderClickActionDefault="SortMulti" Name="UltraWebGrid1" RowHeightDefault="20px"
RowSelectorsDefault="No" SelectTypeRowDefault="Extended" StationaryMargins="Header"
StationaryMarginsOutlookGroupBy="True" TableLayout="Fixed" Version="4.00" ViewType="OutlookGroupBy">
<GroupByBox>
<BoxStyle BackColor="ActiveBorder" BorderColor="Window">
</BoxStyle>
</GroupByBox>
<GroupByRowStyleDefault BackColor="Control" BorderColor="Window">
</GroupByRowStyleDefault>
<ActivationObject BorderColor="" BorderWidth="">
</ActivationObject>
<FooterStyleDefault BackColor="LightGray" BorderStyle="Solid" BorderWidth="1px">
<BorderDetails ColorLeft="White" ColorTop="White" WidthLeft="1px" WidthTop="1px" />
</FooterStyleDefault>
<RowStyleDefault BackColor="Window" BorderColor="Silver" BorderStyle="Solid" BorderWidth="1px"
Font-Names="Microsoft Sans Serif" Font-Size="8.25pt">
<BorderDetails ColorLeft="Window" ColorTop="Window" />
<Padding Left="3px" />
</RowStyleDefault>
<FilterOptionsDefault>
<FilterOperandDropDownStyle BackColor="White" BorderColor="Silver" BorderStyle="Solid"
BorderWidth="1px" CustomRules="overflow:auto;" Font-Names="Verdana,Arial,Helvetica,sans-serif"
Font-Size="11px">
<Padding Left="2px" />
</FilterOperandDropDownStyle>
<FilterHighlightRowStyle BackColor="#151C55" ForeColor="White">
</FilterHighlightRowStyle>
<FilterDropDownStyle BackColor="White" BorderColor="Silver" BorderStyle="Solid" BorderWidth="1px"
Font-Size="11px" Height="300px" Width="200px">
</FilterDropDownStyle>
</FilterOptionsDefault>
<HeaderStyleDefault BackColor="LightGray" BorderStyle="Solid" HorizontalAlign="Left">
</HeaderStyleDefault>
<EditCellStyleDefault BorderStyle="None" BorderWidth="0px">
</EditCellStyleDefault>
<FrameStyle BackColor="Window" BorderColor="InactiveCaption" BorderStyle="Solid"
BorderWidth="1px" Font-Names="Microsoft Sans Serif" Font-Size="8.25pt" Height="200px"
Width="325px">
</FrameStyle>
<Pager MinimumPagesForDisplay="2">
<PagerStyle BackColor="LightGray" BorderStyle="Solid" BorderWidth="1px">
</PagerStyle>
</Pager>
<AddNewBox Hidden="False">
<BoxStyle BackColor="Window" BorderColor="InactiveCaption" BorderStyle="Solid" BorderWidth="1px">
</AddNewBox>
</DisplayLayout>
<DataRelations>
ParentColumns="SCMatrixID" ParentDataViewID="SqlDataSource1_DefaultView" />
</DataRelations>
<DataViews>
<cc1:DataView ID="SqlDataSource1_DefaultView" DataMember="DefaultView" DataSourceID="SqlDataSource1" />
<cc1:DataView ID="SqlDataSource2_DefaultView" DataMember="DefaultView" DataSourceID="SqlDataSource2" />
</DataViews>
</cc1:WebHierarchicalDataSource>
<asp:SqlDataSource ID="SqlDataSource2" runat="server" ConnectionString="<%$ ConnectionStrings:SRSConnectionString %>"
SelectCommand="SELECT * FROM [SalesCommissionMatrixDetail]"></asp:SqlDataSource>
<asp:SqlDataSource ID="SqlDataSource1" runat="server" ConnectionString="<%$ ConnectionStrings:IRS_QAConnectionString %>"
SelectCommand="SELECT * FROM [SalesCommissionMatrixHeader]"></asp:SqlDataSource>
</body>
</html>
Please, also check out this thread for details on the other problem you are having.
Oh, so is that a Script Manager for Ajax. I'm in VS 2005 so I guess that's why I don't see it
Typically a ScriptManager tag is added after the form tag and can look like this:
<asp:ScriptManager ID="ScriptManager1" runat="server"/>
If you create a new "AJAX Web Form" in the add files dialog in VS 2008, it will do this for you.
Tom
