570
WebGrid & LinQ - displaying hierarchical data - Part II
HI all !
I've created an sipmle class LinqNorthwindDB (see code below) wich uses the Linq2SQl generated code from microsofts Northwind database.
On a asp.net page I connected a ObjectDataSource to this class with "List<Customer> GetCustomers()" as select method.
Connect this ObjectDataSource to a WebGrid works.WebGrid
In WebGrid's designer mode, only the root band will be displayed, not it's child bands.
WebGrid3
Why are those child bands with their columns not available ?
 Any hint or idea is welcome. Thanks in advance !
Claus
public class LinqNorthwindDB [
     private DataContext dataContext; // the linq context from Northwind database
     public LinqNorthwindDB() : this(WebConfigurationManager.ConnectionStrings["Northwind"].ConnectionString){}
     public LinqNorthwindDB(string connectionString){
 dataContext = new DataContext(connectionString);
DataLoadOptions loadOptions = new DataLoadOptions();
         loadOptions.LoadWith<Customer>(customer => customer.Orders);
          // Use these load options to retrieve only a subset of order records;
// loadOptions.AssociateWith<Customer>(customer =>  from order in customer.Orders where order.OrderDate > new
// DateTime(1998,1,1) select order);
         dataContext.LoadOptions = loadOptions;
        public List<Customer> GetCustomers(){
            // The no-expression approach.
            //return db.GetTable<Customer>().ToList<Customer>()
            // The LINQ expression approach.
            var matches = (from customer in dataContext.GetTable<Customer>()
                           select customer);
            return matches.ToList<Customer>();
  • 8680
    Claus,
    For some reason, the images in your post are missing.  Could you re-post them?
    In the past, I've had trouble attaching two images to one post, so I suggest you post them in separate posts.
