I get the following error on trying to build the webchar with my application:
[java] Cause: Class 'com.infragistics.faces.chart.renderkit.html.ChartRenderer' is missing a runtime dependency: oracle.classloader.util.AnnotatedNoClassDefFoundError: [java] [java] Missing class: com.infragistics.faces.shared.renderkit.html.BaseHtmlRenderer [java] [java] Dependent class: com.infragistics.faces.chart.renderkit.html.ChartRenderer
Hi, you must include in your classpath shared.jar.
Best Regards, Nina
