I am using infragistics webgrid for the first time. I want to know how to implement grouping in webgrid at runtime and design time both.
Please reply if anybody knows immediately as it is urgent to me.
Thanks N Regards,
Vallamreddy VenuGopal
At design-time, you should be able to drag existing column headers to the group-by area. This is the same way that the end-user can group a grid by a column at runtime, so long as you haven't hidden the group-by area.
At runtime in server-side code, you can set an individual column's IsGroupByColumn property to true, which will act as if you just added this column to the group-by header. This is useful if you are hiding the group-by area, but still want to group by certain columns in program code.
