Hallo Together,
i have a problem with the new hotfix for ASP.NET 2008 Volume 2 for 3.5.
I have a masterpage, a Contentpage with two Tab Controls. In both Tabs i use a UserControl with include a WebGrid.
If i open the first Tab, so the Grid is viewed and no problems.
If i change to the next Tab, so if i go with the mouse over the header of this WebGrid, so i receive an error. ('editorControl' is Null oder kein Objekt)
This error comes from ig_WebGrid.js --- function igtbl_inEditMode(gn)
Called this function comes from ig_WebGrid.js ---- function igtbl_headerMouseOver(evnt, gn)
in this function you added a new line in this hotfix:
if (!igtbl_lastActiveGrid || igtbl_lastActiveGrid.length<0 || !igtbl_inEditMode(igtbl_lastActiveGrid))
igtbl_lastActiveGrid=gn;
Is that a bug in Hotfix or what can I do?
Thanks for reporting tihs one and especially for the time you invested in going throgh the different versions. From what I see, this could very well be a problem. However this is a peer to peer forum and while I can escalate that, I think in these types of situations the fastest and best way to proceed for all parties if to contact Developer Support directly through official channels.
http://devcenter.infragistics.com/Protected/SubmitSupportIssue.aspx
This way, you will receive an official reply if this is a bug or not (and if not, how to deal with it) and in case of bugs you will have a very easy way to track its progress (you will be notified for status changes). I think long term the official channel is the better way to track this kind of interaction, compared to our Peer-To-Peer forums.
HTH,
