755
problem with dateChooser and converter
I have the following problem with dateChooser. I have element
<ig:dateChooser value="#{iterationController.iteration.plannedEffectivityStart}" converter="shortDateConverter"></ig:dateChooser>
where I use "converter" attribute. I have defined and implemented converter. First definition in faces-config.xml:
<converter>
<converter-id>shortDateConverter</converter-id>
<converter-class>com.anect.rmt.web.converters.ShortDateConverter</converter-class>
</converter>
ShortDateConverter implements Converter interface:
public class ShortDateConverter implements Converter {
public Object getAsObject(FacesContext context, UIComponent comp, String date) {
public String getAsString(FacesContext context, UIComponent comp, Object date) {
When I want render the page, I see exception:
java.lang.IllegalArgumentException: argument type mismatchat sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at javax.faces.component.UIComponentBase$AttributesMap.put(
UIComponentBase.java:1587)
at javax.faces.component.UIComponentBase$AttributesMap.put(UIComponentBase.java:1496)
at javax.faces.component.UIComponent.setValueExpression(UIComponent.java:251) at com.infragistics.faces.shared.version.UnifiedInput.setUnifiedValueExpression(UnifiedInput.java:27)
at com.infragistics.faces.input.taglib.html.DateChooserTag.setProperties(DateChooserTag.java:303)
I use JSF 2008.2 version. Thanks.
ANECT
