Kindly disregarding the post as I decided to back out of the 2008 V8.2 upgrade, now my page is working (somewhat).
Thank You.
MsBajanLady
_________________________________________________________________________________________
I installed, then removed 2008 V8.2.Now my page will not work. I re-ran the Hot-Fix for 2006 V6.3, howver to no avail.
I can only find one instance of Infragistics2.WebUI.UltraWebGred.v6.3.dll.
Now, things have gone from bad to worse as I now have an error "Error Creating Control - ubGridExDuplicate compnonent name 'ugGridEx'. Component names must be unique and case-insensitve.
I can not find what this error is referencing. This what I have.
Note, everything was working before installing 2008 V8.2.
<%@ Register Assembly="Infragistics2.WebUI.WebDateChooser.v6.3, Version=6.3.20063.53, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb"
<%@ Register Assembly="Infragistics2.WebUI.UltraWebGrid.ExcelExport.v6.3, Version=6.3.20063.53, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb"
<%@ Register Assembly="Infragistics2.WebUI.UltraWebGrid.v6.3, Version=6.3.20063.53, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb"
Namespace="Infragistics.WebUI.UltraWebGrid" TagPrefix="igtbl" %>
(B) web.config
<add assembly="Infragistics2.WebUI.Shared.v6.3, Version=6.3.20063.53, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB"/>
<add assembly="Infragistics2.Excel.v6.3, Version=6.3.20063.53, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB"/>
(C) Ex.aspx.vb
ugGridEx.DisplayLayout.Pager.CurrentPageIndex = e.NewPageIndex
Bind ugGridEx()
End Sub
