125
Copying cell value to clipboard even if whole row is selected
In my application there is WebGrid. I have added client side event on cellclick that programmatically selects row which clicked cell belongs to.It just invokes the setSelectes() method on active row. The problem is that i would like to keep the functionality of copying clicked cell value into clipboard even if clicking on the cell makes whole row selected. After adding this event whole row selects, which is fine, but values from all cells in that row copies into clipboard. The DisplayLayout CellClickActionDefault is set to CellSelect.
powersystem
  • 28464
    I am not sure this one would be easy to implement, but maybe you can try this path - hook the client side BeforeClipboardOperation (or AfterClipobaord...) event of the grid documented here:
    http://help.infragistics.com/Help/NetAdvantage/NET/2007.2/CLR2.0/html/Infragistics2.WebUI.UltraWebGrid.v7.2~Infragistics.WebUI.UltraWebGrid.ClientSideEvents~BeforeClipboardOperation.html
    And try to explicitly change the clipboard with javascript in the event handler as described here:
    http://www.geekpedia.com/tutorial126_Clipboard-cut-copy-and-paste-with-JavaScript.html
    However this will only work in IE and could be tricky to do.
