I am using infragistics V7.2 and firefox V3.0.1. I have a webgrid inside a model popup(ajax toolkit) and when AllowAddNewDefault="Yes" is set on display layout, the grid does not show up in firefox. This works fine in IE.
It's nothing to do with the data or type of grid, it because I am using grid inside a modal popup, the same grid shows up and works fine if I remove it from modal popup in Firefox
Any help would be appreciated.
If someone else is having this problem, this seems to work fine in latest version of infragistics 8.2.20082.2022.
Hi Rumen,
Thanks for the suggestion.
It looks like Infragistics V7.2 does not has WebDialogWindow, can you suggest me a workaround\fix if I do a sample & attach with the above mentioned issue?
Many Thanks
It is a bit hard to tell, this could be a specific issue in the implementation of the Modal Popup extender from Ajax Control Toolkit. I have a suggestion though, why not try using our own WebDialogWindow control, which is much more powerful and provides great styling? Maybe you will get better results with it?
Samples on WebDialogWindow can be found here:
