200
WebDateTimeEdit: EditModeFormat not changeable in properties window?
why is the EditModeFormat property not changeable in the properties window? I already changed "DataMode" to "EditModeText".
Mark Junker
  • 24497
    I can not explain why you have problems with setting property. Maybe somewhere design time exception happens or similar. Please, test following:
    1. Create temporary page
    2. Drop WebDateTimeEdit on it.
    3. Set those properties which you have problem with.
    4. Check if they have effect.
    I hope it will work. Now try to move parts of your original page to that temporary and every time check if properties have effect. I think it will help you to find reason which causes that problem.
