I'm using WebGrid instead of an ordinary HTML-table thus I don't need the row selectors but when I set 'Row Selectors' to 'Do not Show' I'm missing the left border of the very left column. I searched through the settings but couldn't find any that seems to influence that border. I did a workaround by inserting a dummy column with width set to 0px which works but that looks also a little odd since I realize that there is a small gap due to the additional column. I'm using NetAdvantage 8.2.
Does anyone know how to set this?
Thanks in advance, Wolfgang
Cool - glad was able to help. I will double check if we have this documented somewhere, since it indeed might not be so straightforward to figure out from the docs/samples.
Hello Wolfgang,
I think I was able to reproduce the problem you experience. The problem appears when you remove the default FrameStyle collection from the grid DisplayLayout setting. Putting the FrameStyle back solves the problem (no missing left border for leftmost column). Is it possible to use FrameStyle instead of the fake first column, e.g.
<displaylayout bordercollapsedefault="Separate" name="UltraWebGrid1" rowheightdefault="20px" version="4.00" RowSelectorsDefault="No"> <framestyle borderstyle="Solid" borderwidth="1px" font-names="Verdana" font-size="8pt" width="825px"> </framestyle>
Width and Height of the frame style can match the width and height of the grid itself.
