We're using version 6.3.20063.53 of the UltraWebTab. It renders correctly in IE6 but in IE7 it will only display some of the data in the tab. It looks like the tab control itself has rendered but data is cut off and the tab won't scroll or expand vertically to display all of the data. Has anyone else come across this? Is there a solution?Thanks!
I think I solved it by setting the height to 100% instead of using a set height in pixels. We've also since upgraded to version 8.3. Hope that will help you out!
Hey Kim,
Can you send us the url for the hotifx?
Hi, I am infact facing the same problem with webtab IE7 compatibility. Did you find a solution to it..Many thanks.
It could be due to IE7 releasing after the release of 6.3.20063.53. I would recommend that you either install a hotfix or upgrade to a later version of the product.
If you cannot upgrade, you may want to play with setting the height on the html, body, form, and the tab control.
Something like this:
<style type="text/css"> html,body,form{ margin:0; padding:0; height:100%; border:none}</style>
