275
AJAX SQLDataSource Refresh
i have the grid bound to the SQLDataSource with a default SQL command such as SELECT * FROM Inventory with AJAX enabled. I also have a querystring request in the page load like the below code. This works for the initial page load anad data in the grid. However, when the grid does the AJAX Recrod retireve when the scrool bar reaches the bottom the data comes with no requard to price. Am i doing something wrong?
f=Request.QueryString("1")
if f ="1" then
   SELECT * FROM Invnetory WHERE PRICE > 1000
   SqlDataSource1.SelectCommand = strsql
    SqlDataSource1.DataBind()
end if
 TIA
Tom
  • 8680
    I don't think Request.QueryString is available if you're doing an AJAX refresh.  I'd create a HiddenField inside your UpdatePanel.  Then, in your Page_Load handler, set MyHiddenField.Value = Request.QueryString("1").ToString()
