I am using XamNumericRangeSlider in my application. I want to do command binding to ThumbValueChanged event using MVVM pattern.
I tried using Microsoft interaction event triggers with Relay Command. I am not able to get it right.
Any kind of help is highly appreciated. Thanks
Hello Anushri,
It has been a while since the last update on this forum thread. Please, keep in mind that we handle a single question per support request. As the initial topic of the current thread was about Command binding and it was already addressed, my suggestion is to create new support cases or forum posts about your new queries. This is to ensure all your issues are handled correctly.
I would just like to mention that, the TickMarksFrequency property is a property of the generic class SliderTickMarks<T> and could not be bound, which would explain any erroneous behavior that you observe. In order to display the tick marks you can set the property to a specific value or it will be automatically calculated by the control.
Best regards, Bozhidara Pachilova
I am facing another issue with the XamNumeric range slider tick marks.
I have done propery binding for number of ticks, Max and Min value.
I m initializaing Max = 100, Min = 0 and TickFrequencey = 10.
Slider and tick frequencey are correct.
Then I am changing it to Max = 1, Min = 0, Tick Frequency = 0.1
Slider and tick frequency are correct.
Again i Change it back to Max = 100, Min = 0 and TickFrequencey = 10.
then tick display is not coming correctly.
Can you help me with this.
My code is mentioned below:
<ig:XamNumericRangeSlider Grid.Row="1" Width="60" x:Name="RangeSlider" Orientation="Vertical" TrackClickAction="MoveToPoint" IsMouseWheelEnabled="True" MinValue="{Binding DoseColourBarLowerRange,UpdateSourceTrigger=PropertyChanged}" MaxValue="{Binding DoseColourBarUpperRange,UpdateSourceTrigger=PropertyChanged}" FontSize="11" IncreaseButtonVisibility="Collapsed" DecreaseButtonVisibility="Collapsed" Style="{StaticResource XamNumericRangeSliderStyle}"> <ig:XamNumericRangeSlider.TickMarks> <ig:SliderTickMarks TickMarksFrequency="{BindingDataContext.TickFrequency,Source={x:Reference ProxyElement},UpdateSourceTrigger=PropertyChanged,diag:PresentationTraceSources.TraceLevel=High}" IncludeSliderEnds="True" UseFrequency="True"VerticalTickMarksTemplate="{StaticResource VerticalTick1}"> </ig:SliderTickMarks> </ig:XamNumericRangeSlider.TickMarks> </ig:XamNumericRangeSlider>
I am glad that you have successfully managed to display the tick marks.
If I understand correctly, the issue you are facing is that both the regular and value tick marks are not displayed for the MinValue/MaxValue. Please, correct me if my assumption is wrong.
What I can suggest is setting the IncludeSliderEnds property of the SliderTickMarks objects to “True”:
<ig:XamNumericRangeSlider.TickMarks> <ig:SliderTickMarks UseFrequency="True" NumberOfTickMarks="10" IncludeSliderEnds="True"> </ig:SliderTickMarks> <ig:SliderTickMarks TickMarksFrequency="5" UseFrequency="True" HorizontalTickMarksTemplate="{StaticResource HorizontalTick}" IncludeSliderEnds="True" /> </ig:XamNumericRangeSlider.TickMarks>
I am also attaching the modified sample showing this as well as binding to the XamNumericRangeSlider’s MinValue and MaxValue properties. On my side, everything seems to be working as expected and no binding errors are observed.
Please, test it on your side and if you require any further assistance on the matter, please let me know.
Best regards,Bozhidara Pachilova
3858.XNRSommandBinding.zip
Thanks for the help.
I used the link and I could dispay the tick marks.
I have done data binding of maxValue, MinValue and tick frequency from code behind.
The MaxValue and TickFrequency binding are working well, but MinValue binding is not getting reflected on tick frequency.
Any Suggestions?
I believe you will find this topic in our documentation about Value Tick Marks very helpful on the matter. There you will find example code on how to define a data template for a tick mark, displaying text bound to its value.
Regarding your second question, I am wondering if you had the chance to test the previously suggested sample on your side? As it demonstrates the XamNumericRangeSlider in an MVVM-like scenario, it has two thumbs, bound to two numeric values of the view model. Both values are set in the view model, that is from code. Upon change, the new values are reflected as the binding mode is two-way.
Sincerely,Bozhidara PachilovaAssociate Software Developer
