I'm trying to turn on custom paging in the grid for the webcombo box. I'd like it to be similar to the Alphabet paging in the grid sample.
In the InitializeLayout event I set the following properties like I would in a grid.
webcombo.DropDownLayout.Pager.AllowPaging = true;
webcombo.DropDownLayout.Pager.StyleMode = PagerStyleMode.CustomLabels;
webcombo.DropDownLayout.Pager.CustomLabels = ALPHABET;
webcombo.DropDownLayout.Pager.PageCount = 27;
The grid is being bound to an objectdatasource which is tied to a DataTable from my business objects and while it is filtered by the letter "A" when it first comes in, there is no paging control visible.
I missed some documentation required XMLHTTP to be turned on so this code is working.
webcombo.DropDownLayout.Pager.AllowCustomPaging = true;
webcombo.DropDownLayout.Pager.PagerAppearance = PagerAppearance.Bottom;
iddlOperator.DropDownLayout.Pager.PageCount = 26;
My problem now is I am limited to 50 rows and setting webcombo.DropDownLayout.Pager.PageSize = 0 does not give unlimited rows as it does with the regular grid.
EDIT: Turned out I wanted
iddlOperator.DropDownLayout.RowsRange = 0;
