Based on the Stack Trace of my error I'm not really sure what's going on but I believe it to be something with the WebCombo. If you guys know of a fix please let me know...Line 22 (Response.Expires = 0) is where I'm getting the NullReference, however as soon as it comes back from code behind and runs through my Response commands, it breaks. Thanks!
.aspx
<%@ Page Language="VB" AutoEventWireup="false" CodeBehind="~/App_Code/frmRateEstimate.aspx.vb"Inherits="frmRateEstimate" debug="True" enableViewState="True" aspCompat="True" errorPage="frmErrorTrap.aspx"%><%@ Register TagPrefix="igtbl" Namespace="Infragistics.WebUI.UltraWebGrid" Assembly="Infragistics35.WebUI.UltraWebGrid.v8.2" %><%@ Register TagPrefix="igcmbo" Namespace="Infragistics.WebUI.WebCombo" Assembly="Infragistics35.WebUI.WebCombo.v8.2" %><%@ Register tagprefix="uc1" tagname="uc_Menu" src="uc_Menu.ascx" %><!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"><html xmlns="http://www.w3.org/1999/xhtml" ><!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN"> <meta content="Microsoft Visual Studio .NET 7.1" name="GENERATOR" /> <meta content="Visual Basic .NET 7.1" name="CODE_LANGUAGE" /> <meta content="JavaScript" name="vs_defaultClientScript" /> <meta content="http://schemas.microsoft.com/intellisense/ie5" name="vs_targetSchema" /> <head runat="server"> <title>Insight Rater - Transportation Insight</title> </head> <% Response.CacheControl = "no-cache"%> <%Response.AddHeader("Pragma", "no-cache")%> <%Response.Expires = 0%>
Line 20: <% Response.CacheControl = "no-cache"%>Line 21: <%Response.AddHeader("Pragma", "no-cache")%>Line 22: <%Response.Expires = 0%>Line 23: Line 24: <script language="javascript" id="clientEventHandlersJS" type="text/javascript" ></script>
[NullReferenceException: Object reference not set to an instance of an object.] Infragistics.WebUI.UltraWebGrid.UltraGridCell.Infragistics.WebUI.UltraWebGrid.IXPathDataNavigable.GetNextSibling() +165 Infragistics.WebUI.UltraWebGrid.XPathDataNavigator.MoveToNext() +56 Infragistics.WebUI.UltraWebGrid.XPathDataNavigator.OutputToStream(XPathDataNavigator xpdn, XmlTextWriter stream, HtmlTextWriter htmlWriter) +294 Infragistics.WebUI.UltraWebGrid.XPathDataNavigator.OutputToStream(XPathDataNavigator xpdn, XmlTextWriter stream, HtmlTextWriter htmlWriter) +284 Infragistics.WebUI.UltraWebGrid.XPathDataNavigator.OutputToStream(XPathDataNavigator xpdn, XmlTextWriter stream, HtmlTextWriter htmlWriter) +284 Infragistics.WebUI.UltraWebGrid.XPathDataNavigator.WriteOuterXml(TextWriter stream) +90 Infragistics.WebUI.UltraWebGrid.RenderXmlGrid.WriteBody(HtmlTextWriter writer, RowsCollection rows, Boolean topLevel) +83 Infragistics.WebUI.UltraWebGrid.RenderXmlGrid.WriteUltraWebGrid(HtmlTextWriter writer, UltraWebGrid grid, Boolean shouldWriteAll) +722 Infragistics.WebUI.UltraWebGrid.RenderXmlGrid.VisitObjects(HtmlTextWriter output) +426 Infragistics.WebUI.Shared.RendererBase.Render(HtmlTextWriter output) +36 Infragistics.WebUI.UltraWebGrid.GridRendererBase.Render(HtmlTextWriter output) +382 Infragistics.WebUI.UltraWebGrid.UltraWebGrid.Render(HtmlTextWriter output) +447 System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) +25 System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) +121 System.Web.UI.Control.RenderControl(HtmlTextWriter writer) +22 Infragistics.WebUI.WebCombo.RenderDHTMLCombo.Render(HtmlTextWriter output) +8927 Infragistics.WebUI.WebCombo.WebCombo.Render(HtmlTextWriter output) +103 System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) +25 System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) +121 System.Web.UI.Control.RenderControl(HtmlTextWriter writer) +22 System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) +199 System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) +20 System.Web.UI.HtmlControls.HtmlForm.RenderChildren(HtmlTextWriter writer) +59 System.Web.UI.HtmlControls.HtmlForm.Render(HtmlTextWriter output) +68 System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) +25 System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) +121 System.Web.UI.HtmlControls.HtmlForm.RenderControl(HtmlTextWriter writer) +37 ASP.frmrateestimate_aspx.__Render__control1(HtmlTextWriter __w, Control parameterContainer) in C:\Projects\TI\Web-Site Conversion 3.5\insightTools35\frmRateEstimate.aspx:22 System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) +98 System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) +20 System.Web.UI.Page.Render(HtmlTextWriter writer) +26 System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) +25 System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) +121 System.Web.UI.Control.RenderControl(HtmlTextWriter writer) +22 System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +2558
Please contact developer support and provide them with a sample that reproduces the problem. Thank you.
I am facing same problem.Since v8.2 it was working but in v8.3 and v9.1 this crash is occuring.
I have no choice except to move older version v8.2.
Can any one help me also.
Thanks & Best Regards
Nadeem
Any ideas? I'm at a standstill
