I have expanded Combo (with reference to Grid)
How I can get Combo row from cell in Grid?
It really depends on the specific situation. An approach that might be applicable in this situation is to hook the grid InitializeRow event and to find the dropdownlist directly from there (I assume that the dropdown will be placed in a templated column): TemplatedColumn col = (TemplatedColumn)e.Row.Cells.FromKey("dropDownContainer").Column; CellItem ci = (CellItem)col.CellItems[e.Row.Index]; DropDownList archive = (LinkButton)ci.FindControl("dropDownListID");
Or if the combobox is inside RowEditTemplate - you can check out this forum thread for additional details>
RowEditTemplate http://forums.infragistics.com/forums/t/11438.aspx
why the dropdown of the webcombo inside the grid is stretched its height when the grid cells are having multilined text?
it doesn't look like an webcombo at all... how to fix this issue?
Arun.K.S
