1414
Hide a row in a WebCombo
To All,
I have a situation where I must display a 'status' in a grid cell managed by a webcombo (ie. a dropdown list in the webgrid).  However, I cannot allow the customer to select that 'status' from the combo box.  Thus, if the status is 'IR' than it should be displayed, but if it is something else the customer cannot select 'IR' from the dropdown.
The best I seem to be able to do is Hide the row, but that makes the value invisible in the grid.
I would like to 'disable' the webcombo row, or hide it without affecting the grid display.
  • 7694
    You can try to validate selected row with JavaScript on client side. Please take a look code below:
    <ClientSideEvents BeforeSelectChange="Check" />
        function Check(comboID){
            var newSelectedRow = igcmbo_getComboById(comboID).selectedIndex;
            if(newSelectedRow == 0){
                return true;
            return false;
        </script>
    Hopes this helps.
