So far the only way I've found to enable or disable text wrap is using the GridItemStyle.Wrap property.
Is there a way to enable or disable it using a css class in my css file and then setting the GridItemStyle.CssClass to that class?
Thanks.
Hey Rumen, i found a way.
I can enable text wrapping defining white-space: normal; in the class assigned to the FrameStyle.CssClass.
My first approach was seting it in the class assigned RowStyleDefault.CssClass. That one doesn't work.
Hello Oscar,
It's a bit hard to tell and really depends on the certain situation, but I can probably give you a clue that can get you started. You can play with the CSS
white-space: nowrap;
attribute and see if it helps. Just be aware, that as with anything browser related, this has its cons and pros.
http://snook.ca/archives/html_and_css/problems_using/
