i have hidden variable which is update when the row is selected in GridView, and i need this value in java script, we are trying to modify in igf_grid.js
this.selectRow=function(domNode,select){
......}}this.customFLT()};
in the customFLT() method just i am tring to print value using alert(of javascript) method, which works fine and i am able to see the value i have seleted from GridView, and i have to use this variable to some other method, when i removed the alert method than i am not able to get the selected value. if i add alert method than its works fine. and i have set " immediate="true" " of hiddenvariable in JSF.
please let me know what is causing this problem.
thanks in advance.
dayananda b v
I will now apply all my source code:
JAVA BackingBean:
GridView grid;
List clientsList = DAO.getClientsList(); // adding some objects
HtmlInputHidden hiddenField1;
public void onChangeSelection(SelectedRowsChangeEvent e) {
String selectedid = "";
if (getGrid() != null) {
Iterator selectedRows = getGrid().getSelectedRows()
.iterator();
while (selectedRows.hasNext()) {
RowItem rowItem = (RowItem) selectedRows.next();
int i = 0;
Iterator iter = (Iterator) rowItem.getCells().iterator();
while (iter.hasNext()) {
UIComponent cell = (UIComponent) iter.next();
Object object = cell.getChildren().get(0);
if (object instanceof UIOutput) {
if (i == 0) {
String selectedUnit = ((UIOutput) object)
.getValue().toString();
selectedid = selectedid + selectedUnit;
i++;
getHiddenField1().setValue(selectedid);
SmartRefreshManager srm = SmartRefreshManager.getCurrentInstance();
srm.removeSmartRefreshIds(getHiddenField1().getClientId(
FacesContext.getCurrentInstance()));
srm.addSmartRefreshId(getHiddenField1().getClientId(
getHiddenField1().setImmediate(true);
System.out.println("getHiddenField1---> "
+ getHiddenField1().getValue());
public GridView getGrid() {
return grid;
public void setGrid(GridView grid) {
this.grid = grid;
public List getClientsList() {
return clientsList;
public void setClientsList(List clientsList) {
this.clientsList = clientsList;
public HtmlInputHidden getHiddenField1() {
return hiddenField1;
public void setHiddenField1(HtmlInputHidden hiddenField1) {
this.hiddenField1 = hiddenField1;
JSP page:
<%@ page language="java" contentType="text/html; charset=ISO-8859-1"
pageEncoding="ISO-8859-1"%>
<%@ taglib prefix="f" uri="http://java.sun.com/jsf/core"%>
<%@ taglib prefix="h" uri="http://java.sun.com/jsf/html"%>
<%@ taglib prefix="ig"
uri="http://es.infragistics.com/faces/netadvantage"%>
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=ISO-8859-1">
</head>
<body>
<f:view>
<h:form id="form1">
<ig:gridView id="grid"
dataSource="#{webGridSelectionBean.clientsList}" pageSize="10"
pageChangeListener="#{webGridSelectionBean.onPageChange}"
dataKeyName="id"
selectedRowsChangeListener="#{webGridSelectionBean.onChangeSelection}"
binding="#{webGridSelectionBean.grid}">
<f:facet name="header">
<h:outputText value="Clients List"></h:outputText>
</f:facet>
<ig:columnSelectRow showSelectAll="true"></ig:columnSelectRow>
<ig:column>
<h:outputText value="Client Id"></h:outputText>
<h:outputText value="#{DATA_ROW.id}"></h:outputText>
</ig:column>
<h:outputText value="Company"></h:outputText>
<h:outputText value="#{DATA_ROW.companyName}"></h:outputText>
<h:outputText value="Reg. number"></h:outputText>
<h:outputText value="#{DATA_ROW.regNumber}"></h:outputText>
<h:outputText value="Selected"></h:outputText>
<h:outputText value="#{DATA_ROW.selected}"></h:outputText>
</ig:gridView>
< <h:inputHidden binding="#{webGridSelectionBean.hiddenField1}"
id="hiddenField1" immediate="true"></h:inputHidden>
<table>
<tr>
<td><h:outputText id="messOnPage"
value="#{webGridSelectionBean.msgRowsOnPage}"
binding="#{webGridSelectionBean.textRowsNoPage}"></h:outputText></td>
</tr>
<td><h:outputText id="messSelected"
value="#{webGridSelectionBean.msgRowsSelected}"
binding="#{webGridSelectionBean.textRowsSelected}"></h:outputText></td>
</table>
</h:form>
</f:view>
</body>
</html>
Changes in igf_grid.js:
Replace the following code
var row = this.getTargetRow(domNode);
row.select();
row.unselect();
if (!ig.isNull(grid) && grid.isImmediateRowsChangeEvent()) {
this.selectRow = function(domNode, select) {
if (!ig.isNull(row)) {
ig.onPartialRefreshDefault(httpReq);
Please, for further help consult our support policies. Thanks in advance!
HI Bozhidar,
as i am not doing any mistake, let me compare with your demo code.
can you please send your demo code to my mail id or you can just add it here, or shall i send all the nessarry files to you?
thanks
