245
Setting value(or index) of dropdownlist to value of index 1 (not 0)
I have a dropdownlist of lookup table items (Yes, No, Exempt) that is within an infragistics ultrawebgrid column. The ultrawebgrid was built via code-behind. There are no HTML or asp tags for the DDL.  I've added a blank row to the top of the DDL via code, so now it shows a blank, Yes, No, Exempt.
How can I set the DDL value to the value of the "Yes" item when the user enters the DDL?  I tried using javascript is the .aspx that is called from the .ClientSideEvents AfterEnterEditModeHandler of the aspx.vb.  However, I am unable to locate the DDL.  I can tell that I get to the cell because I have an alert set, but I am having troubling extracting the value from the list.
function enterGridRow(gridName, cellId) {                        var oGrid = igtbl_getGridById(gridName);
var oCell = igtbl_getCellById(cellId);
        if (oGrid.ClientID == '<%= CheckListGrid.ClientID %>') {
if (oCell.Column.Index == 4) {
                window.alert('In IF 2');
for (var i = 0; i < oGrid.options.length; i++) {
                   if (oGrid.options[i].value == "Yes") {
                      oGrid.options[i].selected = true;
                     break;
