Hello Team,
xamReportViewer must display the report and after few seconds lets say -10secs , it should be automatically refresh to update the view. Report will get the data from database.
How to implement this in MVVM using c#?
Hello,You can force the report to refresh by calling the XamReportViewer.Refresh() every minute as the report will not automatically update when the data source is updated.Let me know if you have any questions.
Thanks for the reply Maria .
My question is how to auto refresh the report for every 1 minute so that it should update the data if there is any change.
Could you help , please?
Hello,You can bind the data in your viewmodel to your report using the DataSources collection of the ClientRenderSettings. Check this document for sample code of how to bind a data sources through the viewer API.Here are the steps that need to be followed:1. Create the report, define a data source and associate it to the item you want to render.2. In your application, add the XamReportViewer and configure it to render the report you have created.3. Configure the DataSources property to bind to data in your viewmodel.<ig:XamReportViewer> <ig:XamReportViewer.RenderSettings> <ig:ClientRenderSettings DefinitionUri="MyApp;component/Report.igr, MyApp" > <ig:ClientRenderSettings.DataSources> <ig:DataSource TargetDataSource="YourData" ItemsSource="{Binding yourDataProperty}" /> </ig:ClientRenderSettings.DataSources> </ig:ClientRenderSettings></ig:XamReportViewer>Where YourData is the data source you have defined and yourDataProperty is a property in the viewmodel.
