I have a requirement where I need to set the width of a column to "Auto". I am able to do this from XAML code but couldn't find a way to set it from code behind.
Though, I am aware that to change the width I can use - column.Width = new ColumnWidth(3.5, true);
but with this approach I am not sure if the width can be set to "Auto".
Any suggestions on this is appreciated.
Thank You,
Raj
Hello Raj,
Thank you for your feedback. I am glad to know that I was able to help you achieve the functionality you were looking for. I believe this thread can help other people looking for a similar solution.
Thank You, Tacho. Worked for me.
Hello Raj, Setting a specific width to any of the Columns can be done by casting the column to it's actual type and setting it's Width property respectively.
For example: (grid.Columns[0] as TextColumn).Width = ColumnWidth.Star;
(grid.Columns[1] as TextColumn).Width = ColumnWidth.Auto;
(grid.Columns[2] as TextColumn).Width = new ColumnWidth(60, false); If you require any further assistance on the matter, please let me know.
Hi Tacho,
The ColumnWidth property mentioned above is available at the XAMGrid level and I don't see it at the column level. My requirement is to set the width of specific column(s) to "Auto".
Hello Raj, In order to set the width of a column in XamGrid to Auto in code-behind, you can set the Width property of the respective column to ColumnWidthType.InitialAuto or ColumnWidthType.Auto. Code-behind: xamGrid.ColumnWidth = ColumnWidthType.InitialAuto; For more detailed information, you can take a look at Change Column Width Settings. If you require any further assistance on the matter, please let me know.
