3806
xamgrid hierarchy children lazy load
i have hierarchical xamgrid. The parent items load first but I want to load the children items when the parent expansion button is clicked and not on load.
please help.
  • 2180
    Hello Gajender,
    I’ve researched your question about lazy loading of the child items in the xamGrid. Unfortunately, there is no built-in functionality to achieve this requirement.
    The expansion indicator will not appear if there are no already loaded child items so you can’t rely on its events (expanding/collapsing) to load data. Eventually, you can handle RowSelectorClicked event to add child data dynamically but this may cause some side effects. You should specify child data type in advance also as well as its columns.
    I have attached a sample application to demonstrate this but have in mind that it may not be the desired approach – child data is loaded on RowSelectorClicked event and the expansion indicator appears afterwards.
    Another option is to suggest new Product Ideas for future versions (or vote for existing ones) at http://ideas.infragistics.com.
    Steps to create your idea:
    1.            Log into the Infragistics Product Ideas site at http://ideas.infragistics.com (creating a new login if needed).
    2.            Navigate to the product / platform channel of your choice (e.g. WPF, Windows Forms, ASP.NET, HTML5 / Ignite UI, iOS / NucliOS, etc.)
    3.            Add your product idea and be sure to be specific and provide as much detail as possible. Explain the context in which a feature would be used, why it is needed, why it can’t be accomplished today, and who would benefit from it. You can even add screenshots to build a stronger case. Remember that for your suggestion to be successful, you need other members of the community to vote for it. Be convincing!
    The benefits of submitting the product idea yourself include:
    -              Direct communication with our product management team regarding your product idea.
    -              Notifications whenever new information regarding your idea becomes available.
    Additional benefits of the Product Idea system include:
    -              Ability to vote on your favorite product ideas to let us know which ones are the most important to you.  You will have ten votes for this and can change which ideas you are voting for at any time.
    -              Allow you to shape the future of our products by requesting new controls and products altogether.
    -              You and other developers can discuss existing product ideas with members of our Product Management team.
    The product ideas site allows you to track the progress of your ideas at any time, see how many votes it got, read comments from other developers in the community, and see if someone from the product team has additional questions for you.
    ExpansionTest.zip
