I have a Gridview and a button on a panel. When I click on the button it saves the data to the database and refreshes the gridview on Infragistics 2007 Vol2. But on Infragistics 2008 Vol 1 Itshows the XML instead of rendering the page. When I removed the SmartRefreshmnager for the grid it saved the data and rendered the page but with the old data instead of refreshing the data.
How can I make it refres the page using the refreshmanager. This code was working on 2007 version but not on 2008 version
Sashi
I am having the same issue. Using Infragistics 2008 Vol 2 and JSF1.1. Is there a solution?
Geoff
I'm sorry but there is nothing I can do more according this topic in the forum anymore. So that we can investigate this in more detail, and provide you with a fix once one becomes available, please submit a support request to Infragistics Developer Support. You can provide the URL of this thread in your support request, so that we know the two are related.
Regards!
hi,
I downloaded the lates version of hotfix 2014 , still we have the refreshmanager problem. Also we from the gridview when we click on a button the page does not render after that. It shows the XML.
Could you pls help us with this.
thanksSashi
Hello, Sashi!
You can find information about our latest Hotfixes at http://blogs.infragistics.com/tags/Hot+Fix/default.aspx, where notifications are published as soon as Hotfixes are released. There you can review the list of specific issues adressed in each release as well.
Regards!--Bozhidar
Hi
Is the fix (patch) released already? It has been 2 weeks and I just checked the hot fix version it still shows as 2010.
